johnakay
I'm look for a straight reamer to ream out 5/8 tubing.
I'm currently making a rack for a Kawasaki ZRX.
the front and rear tubing the inside bore is a dead tight 1/2" and I can't get the 8mm Allen bolt head through it.
I cant buy a thinner wall tubing because there is a 1/2" tubing insert inside.
I only need to open it by 1mm. could use the drill but the ******s bite the tubing and as you know you cant tightened the vice to much as this will distort the tubing.the wall thickness I think is 1.6mm.
the question is ..is there such a thing as a straight reamer?? where can I get one fron(not to expensive. cheers. john
