N norrie499 New Member Messages 3 Jul 3, 2017 #1 Hi all,I've been given an old record number2 vice but there is some damage to the threads and I was wondering if anyone knew what the size is so I can order a die to clean it up I know it's 1/2 in but that's all THANKS IN ADVANCE
A Arclikeharrypotter Member Messages 1,245 Location Northampton Jul 3, 2017 #2 Unless you want to keep it original you could always thread with a tap size you have close to hand, and use new bolts?
Seadog Save the planet. It's the only one with rum! Messages 13,359 Location NE London - UK Jul 3, 2017 #3 I'm guessing he means the main screw, not the jaws, hence the need for a die. I'm guessing it's ACME but far from certain.
A Arclikeharrypotter Member Messages 1,245 Location Northampton Jul 3, 2017 #4 I think you could be right there! 1/2 would be rather on the large size for jaw bolts! Need to engage brain more often!
N norrie499 New Member Messages 3 Jul 3, 2017 #5 Cheers lads I have found out it is indeed an 1/2in ACME now all I have to do is find where to get one
Seadog Save the planet. It's the only one with rum! Messages 13,359 Location NE London - UK Jul 3, 2017 #6 One possibilty. It depends on pitch. https://www.rdgtools.co.uk/acatalog/ACME_TAPS.html
Rig Pig Member Messages 3,727 Location Narrwich! U.K. Jul 3, 2017 #7 If it's not too bad just carefully file the damage bits - cheaper that a tap for a one off job.
N norrie499 New Member Messages 3 Jul 3, 2017 #8 cheers for the link Seadog I will have a go with a file first
