sako243
- My mansion in Wales
I thought I'd appeal to the collective knowledge here - to see if anyone has any experience with / recommendations for the following: a CNC "machine" that can take ~A3 on the bed, needs to have a Z axis height of a few inches. I don't actually care whether it's a mill, 3D printer, router etc.
All I'm actually interested in is the XYZ movement - I'm doing some R&D which involves scanning a sensor node across a surface - the separation from the surface is crucial and small. XY resolution / accuracy is less important (in fact it's a non-event) but I ideally need close to or better than 10um resolution, and more importantly repeatability, in Z. I'm after the mechanics more than anything else - driving the lead screws / ballscrews with stepper motors will be trivial enough.
I'm umming and ahing over building one from scratch but the time involved makes buying something (even if part of it's thrown away) as a basis much more appealing. E.g. a 3D printer / router / mill and then basically just remove the head and replace with my custom sensor.
Budget is flexible (can claim VAT back as well), willing to spend more for something that's more versatile, e.g. if it could be used for milling aluminium / laser cutting etc., then would be willing to spend more as then it can be used outside this particular project.
