I’ve got a couple of these yellow Gloria ones I picked up from work (they sent a few out to spray the inside of burner chambers with rigidiser fluid - I “disposed” of the unused ones).Gloria
GLORIA Primex 5 Litre 3 bar Garden Pressure Sprayer Piston Pressure gauge - with safe stand, extension lance, compressor connection https://www.amazon.co.uk/dp/B000957U8Q/ref=cm_sw_r_cp_api_i_uaVkFb22P939W
They are more expensive than the usual cheap ones but they are very good quality - I use one for spraying garden fence panels.
Yes, works brilliantly.Every time my back aches from pumping mine up I ponder the possibility of drilling a hole in it and fitting a tyre valve.
Anyone actually ever done that?
Sound logicThanks guys. I’m going to get a Gloria. If for no other reason than I can proclaim to our lass that I’m ‘off outside to give Gloria a Good pumping’![]()
Ha ha, I had no idea they even did them! I just popped outside to see if the ones I have are equipped with this, but I guess either mine was an older version (they are at least 10 years old now) or more likely work went for the cheapest option.Oooh! Hops up and down with excitment:
