Rovers are notorious for being under serviced as owners just thought the regular top ups would suffice.
@Stueeee what's gunwash please?
Aha thanks!Cheaper thinners used to clean spray guns, I believe some of it may be recycled
i don't like or use the stuff why loosen all the solid crap that isnt going anywhere loosen it all off then it goes through your engineSome engines stipulate no flushing oils to be used.
you would be better off getting some cheap oil run it fot a 100 miles then empty and put decent stuff in if u wanted it cleanI'm highly skeptical whether so-called flushing oil does even loosen baked-on, carbonised stuff.i don't like or use the stuff why loosen all the solid crap that isnt going anywhere loosen it all off then it goes through your engineyou would be better off getting some cheap oil run it fot a 100 miles then empty and put decent stuff in if u wanted it clean
hi
can anyone recommend a good petrol engine flush ?. i have taken off sump and removed all the rubbish . its on my wee 3.5 v8 rover
regards
