carlos420uk
In the garage....
Having recently invested in a 200amp AC/DC Tig I have been having a lot of fun learning the process. With the machine (R-Tec Tig 201) I got a "Cheap" style dual gauge regulator along with a flow meter to take a reading at the Torch. Now my question is which should I trust as correct? As when the flow meter on the Regulator reads 6-8lpm the flow meter at the torch reads way over that. Vice versa if I set the gas flow from the Torch the regulator basically reads 0 flow rate.
Common sense tells me that the regulator is wrong and the flow meter is correct (I hope!) but thought I'd ask just to check as I am on my third "Midi" size Argon bottle already and I've only had the machine 3 weeks
Thanks in advance,
Carlos.
Thanks in advance,
Carlos.
