ab56452001
Big Al
- Adelaide South Australia
Hi again. found an old arlec weldmate 140 , made in britain ! , its quite heavy , ive test welded it a bit seems to run ok . On the top is a gauge that reads up to 140 amp as it moves with the big three pronged dial on the front, when i look at the specs plate on the front it says rated to 125 amp ( dont know ac or dc ) duty cycle 25% , what is meant by rated amps ? , by the way i ran 4 3.2 gp rods straight on 4mm mild steel , penetration o'k' , weld looks good and welder,s overload did'nt come on , seems to be an oldy but a goody , for 50$ anyway ! , havent seen anything around here made in the U.k. for a while !...........
