normspanners
Hi guys just a little tip I have toyed with for awhile, was doing some work with my little portable 160 but it was not doing it, felt like there was no power but I was on a VE----RY long extension. etc and needed more power.
I had the idea years ago but have never tried it till I was pushed I had a commercial battery in the back of the disco so with jumper leads put it in series with the earth ie welder earth to the pos. neg on battery to earth, so therefore raising the voltage by 12v. with a little adjustments lowering voltage and upping wire, It worked a treat.
I could easily weld 6mm the only downside is that the torch is semi live because the other side of the coil I say semi live it will spark slightly, so you have to watch that you dont ground it before hitting the trigger.
But it enabled me to weld whereas it was impossible before, you can still adjust voltage and wire enough to get a decent run. I did a fair amount of welds that day put the battery in the disco and forgot, then had flat battery on a car few days later still plenty of umph to start it.
So from that wouldnt have thought welding with it hammered the battery too much.
not to do that again
