http://www.screwfix.com/prods/46110...ion-RAGE255-255mm-Sliding-Compound-Mitre-Saw# are these up to much and how well to they cope with mild steel?
thanks
thanks
i dont like them myself. i think the conventional type of saw fitted with a disc is better.
Any particular reason?
The only down side I know of is the fact that the chop saw has a 2 horse motor with no soft start.
Chris.
I have the rage S210 sliding mitre that I got from screwfix on a previous offerHi,
I have a Rage saw and have cut 40mm box 2mm wall, 20mm x 6mm flat mild steel with no problems.
It does chip away at the metal but i've never had a nasty burr on the metal left by the blade, just needs a quick rub with the file and i've never seen the metal fly arount that badly, yes wear goggles and gloves and it's fine!
Maybe your blade is blunt, missing teeth, or you are pushing the blade through the metal to fast? Worth a check?
Cheers,
Dave.
The dewalt blade cost more than this saw total !!
) it's OK. Ish.
