Hi guys i bought an Rtech mig 180 a couple of weeks ago and have been playing around with it, so far have built a 22" sheet metal bender and a welding trolley from old angle i had laying around, the thing is i bought it to do panel work on my T25 camper van, i was just wondering if anyone knew roughly what settings i should be aiming for?, its 0.6 wire i'm using along with argosheild 5, as you can imagine i don't want to blow through the new panels, i've kinda been guessing so far but i guess you can get away with that more on 3 mm thick angle stock, some panels will require plug/spot welding and there will be one where i will need to run a seam where the old panel will be cut off and new one butted up against it or on top/overlapping slightly its the tall rear arch panel with the sliding door side as i know there is one or 2 guys on here with a T25
Cheers in advance
Cheers in advance
