MattH
- Cornwall
I am installing an 32A Isolator - DOL - 32A Socket to run a vacuum pump.
The singles are installed in a 4" Galv trunk which is above a machine platform. I will drop down from the trunking via 25mm conduit into the Isolator and then into the DOL but then back up the conduit into the trucking and the drop out of the trunking again with 25mm to a socket where the pump will plug in.
This is so I can keep the pump up on the platform but switch it with the DOL from below next to the CNC it supplies.
Question is do I need to run the CPC down into the isolator and DOL and then back up or can I just run the CPC direct to the Socket thereby keeping two cables out of the 25mm conduit that runs to the DOL?
The Isolator and DOL are both double insulated devices but they do both provide an earth stud inside.
