so it is possible with surprisingly good results
This may help you ?
So for a couple of one off,s it may work,it may be ugly but it works.hey just found this.....use a really thick tungsten. Needs testing as a 2.4 just fouls up.
Thats the sort of info i like to read Richard...cheersAluminium has a self generating oxide layer. This means if you scrub it off within 2 hours it will be back. This oxide layer needs to be lifted off and pushed to the side in order for you to generate a puddle on the Alu itself. This is where the positive half cycle of the AC comes in. It attacks at and lifts the oxide layer off making way for the low melting Alu that sits under it. On DC you will have more success with helium as it runs quite a bit hotter giving more chance of melting the oxide layer which melts at 3x the temp of the Alu. What you'll find if you try to do it is the Alu under the oxide layer melts first making it look like your feeding the filler under a carpet. It's far from a nice process and personally unless it was a one off and I had no choice I would not do it as it can't be done to a nice standard.
yea thats all i need..few repairs around this place that does,nt justify buying another AC TIG machine.ive done it with mig years ago but never did much just repairs on a few things, it takes a little getting used to like moving a lot faster
just practice on some scrap you soon get the hang of ityea thats all i need..few repairs around this place that does,nt justify buying another AC TIG machine.
thats easy...all i own is scrapjust practice on some scrap you soon get the hang of it
lol just remember you liner will need to be able to take 1mm wirethats easy...all i own is scrap![]()
Alu is always welded on DC+ with mig.ive done it with mig years ago but never did much just repairs on a few things, it takes a little getting used to like moving a lot faster
no ime talking my DC tig...using that instead of miglol just remember you liner will need to be able to take 1mm wire
oh right I missed that bit lolno ime talking my DC tig...using that instead of mig![]()
Take on only the work within the capability of your equipment. There is no shame in turning a job down because your gear isn't right to make it a perfect job but there is lots of shame handing someone a piece of work with a scabby looking weld on it. Its not a nice way of doing it and even worse if your just using argon alone. Stick to the stainless jobs. The last lot of runs I saw you did looked really good.no ime talking my DC tig...using that instead of mig![]()
I'm also not a fan of Alu mig for the same very reason. If it's not a push pull system it's a lot of messing about. BIG fan of Alu tig Mind AC of course. Results can be gorgeous if all is singing well.The problem that I have always had with migging Ally is that the slightest bit of tip stick and the wire birds nests up after the feed rollers. Backing off the roller pressure results in erratic wire feed, so it's basically pull the liner straight and do a big run or out with the wire snips again (yes I fully set the machine up for Ally). That's why I try to avoid Alu work and stick to what I do best-ferrous. There are times I have need to do a small tack on something alu and like I said its possible to get it to stick with the tig, but pretty it ain't. I just avoid big runs in that stuff these days.
