I have the Clarke 160TM mig welder and have used the online hobby mig welding calculator. The power settings state the following
power setting 1: 0.9 to 1.1 mm
power setting 2: 1.1 to 1.5 mm
power setting 3: 1.6 to 2.0 mm
power setting 4: 2.1 to 2.6 mm
power stting 5: 2.7 to 3.5 mm
power setting 6: 3.4 to 4.3 mm
My question is are these settings applied to the total thickness of the 2 materials being welded together? As an example if I am welding car body panels of say 1.5mm thick together, then 2 of these would equal a total thickness of 3mm. As a guide does this mean I would use power setting 5 as this specifies 2.7 to 3.5mm, or would I go on the individual piece thickness and use power setting 2 as this specifies 1.1 to 1.5mm?
Also what power setting should I use if I am welding different thickness material such as 3mm box to a car body panel? Or say welding a solid bolt to a car body panel (for making up a bracket)
I know these are guides only, but I am really new to this so would appreciate a rough idea.
