AndyStobbs
- North West England
Just wanted to pick the brains of those members who have experience of machining parts to achieve different fits.
I have been making a repair part for a machine that formerly had a taper fit with key between the shaft of a hydraulic motor and a wheel for driving the machine.
I have turned the (damaged) shaft down to a parallel size and machined a top hat shaped sleeve to fit the shaft.
The wheel in turn is bored out to a parallel size so as that the sleeve OD is a sliding fit inside it. The wheel being secured to the top hat with bolts - much like a car.
Question relates to the fit between the motor shaft and the new sleeve. The shaft ended up at 1.027" so based on previous experience (I'm not a machinist by trade and have had no formal tuition in such) I fancied a 0.002" squeeze as it were. So bored the sleeve to 1.025", with a gentle lead in. The contact area between the two is 1.5" long. I was quite surprised to find it took 25 Ton to mate the two in the press.
Is it that my measuring equipment is off or is that pretty much the norm?
FWIW I have come to feel that two parts made to the same size give a press fit that can be easily achieved in the vice or with smallish threaded bar ie. 8mm.
0.002" over size seems to make for a nice sliding fit, such as found between a pulley to be grub screwed to a shaft.
Are my measurements incorrect?
