So how do I achieve spray transfer, and why is it better for Aluminium?
What do the inductance settings look like on a MIG unit? Is there a diagram etc? are they on the front panel or inside the machine itself?![]()
AWH - spray kicks in above 25v, ish, not 250. QUOTE]
I suggested a 250a (not 250v) machine as a minimum in order to ensure you get the voltage and wire feed speed
I know. The OP put 250v in his first post. I wasn't correcting you BP.![]()
Provided the machine offers the option of different inductance settings you adjust it either by putting the work return lead into different sockets or by a rotary dial or keypad control
Its a matter of turning the volts and wire feed up (making sure you keep them in balance) until, instead of getting an individual droplet transfered with each short circuit, you get a constant stream of droplets transferred across the arc without any short circuiting occurring. The main difference you will initially notice is the noise
You need to have a machine capable of running reasonably high volts and amps (probably above 250a depending on wire size) and preferably a 4 roller drive to ensure good feed at higher speeds
The reason it is better on aluminium is because of the increased heat you are putting into the weldpool which in turn improves weld quality.
To be honest you are better off using spray transfer whenever possible on all materials
What about ultra thin sections of mild steel for example? would s. circuit be less likely to blow through than spray? Cheers.
Inductance only works in dip transfer, in basic terms it alters the speed at which the wire heats up to melting point during each short circuit.
As this only occurs during short circuiting it makes no difference when in spray transfer
So what inductance setting should I be using for welding Aluminium
( between 1-10)?
