SV1BDO
- Greece, Egio City
Hi to all, I have bought a Riland 175GD multi mode (3-in-1) machine & have less than a year of occasional experience in welding, mainly on gavalized square hollow sections, using flux wire E71T-11 with good results.
I tried to weld also aluminum square tubes (6063T6 alloy, 2mm thickness) using 0,8mm 5356 wire & Argon gas, but the results did not satisfied me. Despite of the thin wire that I used (they told me that I should use 1,0mm wire), the major problem was that I had some swelling points at the back of the welding points, that I don't want at all, as they obstruct the functionality of the square tubing. I have asked an experienced TIG welder to make a sample for me and the results were superb.
As I am going to make these Alu weldings more often (always welding square box sections), I am thinking either to upgrade the exisiting MIG machine to a PULSE MIG, or to buy an AC TIG for the Alu jobs. The maximum Alu thickness that I will weld will be 4mm. My site has only 1 phase.
Bellow is a short list of PROS & CONS on both options, please feel free to add yours.
PROS of TIG = Superior results, I believe also that I will have not the swelling points on the back of welded surfaces.
CONS of TIG = Needs extra time practice for learning. Maybe more time expensive.
PROS of PULSE MIG = No need for extra learning. Welding progress will be shorter (compared to TIG)
CONS of PULSE MIG = Maybe the welds will not have the same nice feeling (compared to TIG) I am not shure if the swelling points will disapeared using pulse welding.
