scotto75
- Bristol
Hi all,
I'm practicing my TIG welding at home so that I can take on more jobs at work, if I feel confident enough to stick my head out and volunteer myself! But I've been struggling recently to get a good puddle formed when working with various joints in 1.5mm and thinner steel box and tubing. I find it a lot harder with the thin stuff to start an even puddle quickly.
For example, I will try to start a puddle on a fillet joint on some 1.2mm box section. I'll point the tungsten at a 45 towards the corner, but it will refuse to pool in the middle or root of the joint and usually blow a hole in the top piece due to hanging around too long.
Once I have a puddle formed I'm usually pushing the puddle and feeding filler. I have loads more confidence and experience with some thicker stuff above 2mm, but the thinner stuff will be the majority of the TIG jobs at my work.
I have an R-tech 160, set at around 60A for 1.5mm or 40A for 1.2mm. I'm using a 1.6mm tungsten sharpened to a long point at 15 degrees or so. I have CK gas saver pyrex #6 lens and gas flow at 7lpm.
What I want to do this week is not to do any long runs, but just practice initiating an arc and forming a puddle. Just repeating that over to get to point where I can get a puddle going quickly and in the right place.
I would appreciate any advice on the following....
1 - Tungsten grind angle. Is there any benefit making a shallower angle of 30-35 degrees when doing fillet joints in thin stuff, to help direct the arc to the centre of the join?
2 - Electrode/torch angle. I usually push with a 10/15 degree movement, but I'm not sure what is the best angle to aim the arc into the joint - for example, on a lap or fillet, should i be pointing the arc towards the bottom piece to give it more heat, or is it better to aim it at a 45 straight at the centre?
3 - Material temperature. I don't have any heating in my workshop so it's as cold as a polar bear's knackers. I tack the metal to get some heat into it but is it worth me preheating the metal to an even temperature to help the puddle form at all?
Any advice or help in just initiating an arc and forming a puddle on a fillet joint in thin steel would be greatly appreciated.
Thanks.
Thanks.
