I saw B.A. Baraccus make one in a barn once on the A-Team. Not sure it was realistic though, as they went on to make a Mastiff out of an old farm truck and some scrap gates.
Have a look through Ron Reil's site, could one of his designs be adapted to your uses?
It's not for any specialised use or such, but none of the readily available ones rock my boat in the design/looks department, and I detest the look of that chrome/nickel plate they seem to put on a lot of them.I think Roofman once posted a picture of a torch/burner type thing for roofing that used less gas than a normal one.
Both, probably. Have been considering trying to adapt an old paraffin blowtorch to make a self contained, portable unit, but also thinking about a torch for connecting to a bottle too. It'd be old fashioned styling though, with both function and form. Sad I know, but I'd like a torch which looks sexy as well as being useful, and none of the manufactured ones do it for me.![]()
Something along these lines?
Just heat it from the front, auto feed solder roll is an optional extra.....How would you get that round the back of the tank in the airing cupboard to fit an end feed joint, does it have an auto feed solder roll ?
correctamondo young Maker...had another pipe introduced into the gas stream pre-burner head and 5 psi of air resulted in a flame twice as hot and half the gas pressure needed. ive used it on flat roofs with great resultsHave a look through Ron Reil's site, could one of his designs be adapted to your uses?
Mine will probably end up being a lot smaller, but will have copper and brass aplenty.
correctamondo young Maker...had another pipe introduced into the gas stream pre-burner head and 5 psi of air resulted in a flame twice as hot and half the gas pressure needed. ive used it on flat roofs with great results![]()
ile dig it out over the w/end...my house is upside down atm due to building work going on mateyAny photo's of yours?
