Lots of nice, gas-cylinder chiminea project ideas hereabouts.....I really must get `round to making one, before the better days ahead.
But, the old propane bottle I have here keeps 'speaking to me'......it wants to be an oil-change funnel; no, really it does!
If I cut that welded seam near the bell-top, remove the handle, invert the bell and mount on some threaded pipe; with another larger dia. pipe to telescope the height adjustment: captive 'spring and ball bearing' to hold the telescoping with ring-notches machined into the inner pipe at various heights: e.g for a car-ramps, inspection-pit, tractors etc.
Castors mounted on a 'cross' base under the cut-down shorter gas cylinder body, which would act as a tank (w/drain cock), with the funnel/pipe assembly atop.
What do you think?.......have I missed anything?......should I listen to the voice of the Master-Cylinder?
