I thought thermocouples worked on heat expanding a liquid inside a pipe that then pushed against a cut off. That means unless you need some sort of extra high temperature capable item any will do and CNC just the same as propane.
http://www.screwfix.com/p/standard-...rch-_-SearchRec-_-Area1&_requestid=161730#_=p
You then need the actual valve -
http://www.gasproducts.co.uk/acatalog/Type_50_FFD_Flame_Failure_Valve.html#aHA550
With shopping around / eBay I'm betting you can get a complete set up of everything required for under £20 including delivery
with jet to suit propane on the thermocouple hot endYou will need the complete fsd and Gas valve
They are but I think the ones needed are different. Although they are commonly called thermocouples they are really a thermo electric valve.Isn't the k-type thermocouple the most versatile and widely used ? We used them to monitor temps in an uninsulated room before and also used them in ovens/kilns. Worked really well.
