Dunno , the doors are propped at the bottom an inch from the skirting board , the other long edge is along the wall , doubt any bowing will occur all door furniture removed and doors trimmed to a few mm bigger than the width of the doors . each door marked on the top and bottom where it is intended to be fitted and where the hinges will be.are you not supposed to lay doors flat before fitting or they might bow ?
i was allways told to after buying doors from any where (internal doors)was to lay them flat some where in the house to get used to the temptures in the house (im assuming thats becasue most are stored in a warehouse that are cold or possably humid)for a few daysDunno , the doors are propped at the bottom an inch from the skirting board , the other long edge is along the wall , doubt any bowing will occur all door furniture removed and doors trimmed to a few mm bigger than the width of the doors . each door marked on the top and bottom where it is intended to be fitted and where the hinges will be.
