from a mk4 4motion golf , depends , easy way for me was use stand alone ecu regards 4wd , just use the 24v and 6speed 02m runin gear , or u can also use the arly vr6 12v but ull need the flywheel and clutch set up to make it workhey very nice project. is the 4x4 setup from a late golf? whats required to get it working? ( the transfer box and that)
thanks
hey nice work . you sound like a guy i could get along with . what ecu's you build megasquirt ? im from wakefield do you ever come over this way ? i may have seen your car
phil
its a ms1 v3 , made to run a wasted spark /on direct coilpack drive, think u can buy a kit from ebay for around 150/350 depening on ur needs ,as i wanted lauch control/direct coil drive , 400kpa map sensor , knock sensor , and run in hi res firmware
I'm intending to put a K27 on my 2 litre pinto blowing throught two DHLA 45M's. But need to finish existing project,the XR4i V6 with a KKK 3LKZ turbo,and I'm half way doing the 4x4 conversion
