Theblackbox
- Somerset uk
im in the process of rebuilding and converting to single phase a bench mounted progress no1. The quill return spring has broken I've measured it as 50mmx16mm I've found one here that measures 50x12mm will the slightly shallower spring cause any issue? Also the eye end of that spring is straight mine is 90 degree to rest of the spring so would it bend ok? Also what's the best way of fitting it.
http://www.amazon.co.uk/Drill-Press-Return-Spring-Assembly/dp/B00A764S2I
Also it's missing its chuck I've measured the taper on the quill externally and at the bottom its 16mm and top its 17mm and there is a threaded section which is 16mm externally so what fitment chuck does it have? I've attached images of both the quill and spring cheers all for the help
