sam_shelton
Hi
I am having problems getting a consistent weld with my new welder. I am using argoshield and 0.6 wire to weld thin plate (0.8mm). I appear to have setup the welder ok and can weld quite nicely but I am getting a fair bit of spatter and sometimes the sound of the weld changes. Is this because of wire feed problems or dirty metal? I have not cleaned the metal up with a wire brush or anything but it looks pretty clean with minimal corrosion.
If I go upto the next power setting on the machine then the problem is not so evident but then I start to blow holes in the metal.
Any advice would be appreciated.
Thanks
Sam
Thanks
Sam
