Hy guys, I've got problem here & I need yours help. Everyone's invited to this riddle, especially YOU guys who are familiar with ESAB & hopefully ULJANIK units.
Thing is, couple of months ago, I was practically given almost unused MIG-MAG welder. It's 20 or so years old machine that has been bought brand new & it NEVER worked fine. Much as I heard about it, they tried to fix it, they called experts to service goddamn thing and it never worked as it should. Then, after maybe half of wire reel burned, they've put it in the corner and bought new welder that still works fine. This one that I've got, has practically never worked, it was parked in the corner of the garage & waited there for 20 years for someone to give him some attention.
When I brought it home, firstly I removed all side panels & cleaned everything with compressed air, I didn't want to plug it in the electricity and burn something inside. Everything inside looked perfectly new, without any signs of wearing or heating, unfortunately I don't have any pics of that, but I'll get some soon.
Welder is "uljanik LDA 400" rectifier with "esab a10 med30 synergic" wire feeder/ ctrl unit.
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG] In next few days I've bought bottle of CO2 30kg, new "messer" valve/regulator and new spool of 0,8 mm mild steel wire. It was time to try some welding and sh!+y machine just refused to give me any life signs. Seems that problem was in old esab standard joint where polycable enters wirefeed unit.
[/URL][/IMG] Trigger wire had bad contact with wirefeeder, when I've fixed that machine finally started to show some life in it.
Biggest problem now is that I can't get that fine flowing zzzzzzzzzz sounding transfer when trying to weld thin material, lets say 1 mm, if I turn power up I get burn through holes, but when I lover the power I get lot of dirt - spatter, high bead & ta-ta-ta machine gun like sound. Exit tips were clogging all the time. It felt like I don't have constant and stabile wire speed. First I've suspected that there's no enough pressure on wire feed rollers, but after few birdnests on rollers, I thought polycable was too long (4,5 meters) and it gives too much resistance to nice wire flow. I tried to press wire sideways in front of the exiting tip with 2 fingers and that was enough to stop the wire. Then I decided to shorten polycable in half to see if thet was the problem. Now I have 2 meters polycable and I cant stop the wire with my fingers but any welding is still impossible.
Guys please help, any advice is welcome and appreciated, I have no idea what to try next. I don't know what info you need to solve this problem, so you ask and I'll try to provide any info I can.
thanks a lot
thanks a lot
If you want to get rid of it, send me a pm hehe
