aniesigh
Hi all,
i've recently switched my wire to some Esab 1250 Aristorod copper free wire and can't get on with it
it just keeps sticking to the tip! i'm not sure if the wire feed is slipping slightly and then it burns back to the tip or what, but if i increase the tension on the wire feed then as soon as it sticks it snarls the wire up down at the feed. its a Lincoln compact 220 and i never had a problem with my old sealey copper coated wire. is there anything i should change when switching to this wire? different type tip etc? oh i tryed changing the tip for a new one several times to no avail, and played around with wire speed again with no luck.
hope someone can help
it just keeps sticking to the tip! i'm not sure if the wire feed is slipping slightly and then it burns back to the tip or what, but if i increase the tension on the wire feed then as soon as it sticks it snarls the wire up down at the feed. its a Lincoln compact 220 and i never had a problem with my old sealey copper coated wire. is there anything i should change when switching to this wire? different type tip etc? oh i tryed changing the tip for a new one several times to no avail, and played around with wire speed again with no luck.hope someone can help
