Jonny Stannard
New Member
Hi
Firstly I'd to say hello
I have a Ferm 150 welder that I bought new and have been using it for at least 10 years without any problems. In that time I have only had to replace the regulator and that was at least 4 years ago. I use the refillable 1Kg CO2 bottles and they normally last a long, long, long time. And I do a fair bit of welding. The last bottle lasted a year!
Anyway I have just replaced a complete sill assembly inner, middle and outer. I have gone through 2 x 1kg bottles and 2 of those little disposable bottles. I've done many sill replacements in the past and I have never used 1, 1kg bottle or maybe it has just run out but thats a lot of welding.
I weld outside so my gas is always up full. It just seems to be a strange problem. The other day I had a brand new bottle just exchanged it as work used my welder to weld some shelving and they ran out of gas. I hooked it up and I did no more than a an hours welding in total maybe a little bit more but you get the idea, it was hooked up for about half a day though as I was making the repair peices as I went.
So just in case and rule these things out I have leak tested it at the regulator, thats fine. I have tested any connections along the hose and they are fine.
Its puzzling me as I never gone through so much gas before, can anyone point out any other areas I should be looking at?
Thanks in advance
Thanks in advance
