Harry Bloomfield
New Member
- Yorkshire
The drive is via a directly driven wheel with two slots, one for each wire size, on top of which there is a bearing to act as an idler wheel. The wire is trapped between these two wheels and driven by them.
The idler wheel is kept in contact via an adjustable tension spring, all mounted on a plastic bracket. All worked fine when I bought it, but now the give in the plastic is allowing the idler wheel is slip off the wire and to one side.
I start welding, the wire comes out, then there is a click as the wheel slips off. I am maybe using too much tension on the wheel, but the wire is simply not gripped and driven if I don't. I'm using the wire which doesn't need a separate gas.
