rikrobson
- Perth, Scotland
I'm reparing the inner wings on My 2.8 Cari and there are strengthening plates over the single skin inner wing at the strut tops. These have has to be replaces as the original ford method was to spot weld then paint. This has resulted in water penetrating the gap between the two plated and rusting from inside out. The inner wing has been repaired and the beads ground flush.
I've cleaned up the upper surface of the inner wing, which is is now bare metal and I am in a position to fix the reinforcing plate which is painted with a black primer, the same as new panels come in.
I really would like your input in how to treat the bare metal surface which will be hidden by the reinforcing. This will be plug welded just as the original wasn't seamed but spot welded on.
Would i be better using a standard zinc primer and remove where the plug welds will be or use a weld through primer? I plan to seam-seal also round the edges, but may seam.
The cut out section in the 2nd picture has been replaced, I just didn't get a photo, I will post later.
