Muckmagnet
- East Riding. UK
Not sure this is an ethical question or not, if it goes against the grain please remove this post.
To cut a long story short, in a years time I'm coming up for retirement but hoping to make a few quid to help out an otherwise not so good pension. The firm I now work for require some brackets making, at the moment we tend to do these brackets on site as they are quite simple although something we could do without., but to make the job tidier I've suggested making these brackets myself at home and supplying them.
The easiest bracket is a 175mm length of 40x40x3 angle iron with two 7mm holes drilled in one side and one 8mm hole drilled in the other, the 8mm hole will need an 8x30 set screw welding in place, all edges and corners to be fettled and spray painted (XG-90 aerosol) black.
Finish isn't a big issue as these will be buried in the bowels of loading shovels.
I was thinking of charging about a fiver per bracket, Do you think this is a reasonable price.
To be made in batches of approx 30, at the moment one batch per month.
You've got to start somewhere.
Thanks.
Chris.
Thanks.
Chris.
