JonnyAlpha
OK so I have laid on a good layer of Epoxy on a mix of bare metal, acid etch and original paint. I have just seam sealed everywhere that needs it.
My intention is to lay on another thin coat of epoxy and then top coat wet on wet on the epoxy.
Bottom line up front, I have wet sanded down the Epoxy with 320 grit to give the next coat of epoxy a key. After going over with 320, as the first coat was a little rough / dimpled I also went over wet with P800, I fear that now the epoxy is to smooth for the next coat??
Will the next coat lay on and adhear to a base coat that has been flatted with P800 or do I need to rough it up again?
Thanks in advance
Thanks in advance
