JonnyAlpha
Hi;
I have been doing some patch welding on my Mini (rust holes in the floor and arches etc).
Because I did not have enough time to do the job in one go I sprayed the area with Acid 8 HERE.
I now need to finish the weld and prepare for spraying.
1. Do I need to remove all the primer before welding?
2. Once a patch is applied and the weld is ground down with a flap disc do the welded areas need to be seam sealed? This is a patch in a floor etc and not a complete panel being welded to another?
3. Is U Pol Seam Sealer from Halfords OK? HERE?
4. Once its sealed I guess I'll prime and spray.
Ta
Thanks
Ta
Thanks
