BigBunny
New Member
- Cambridge, UK
Hi Folks,
Thought I would post my latest practice welds. Only been doing this a month or so.
These are on 1.5 inch 16swg Box Tubing. My Clarke 135TE is set to 1, MAX with a wire speed of 7. Gas (Argon / C02 / 02 mix) is set to 8 LPM.
I seem to get similar results on gas at 4 – 8 LPM. At 8 LPM is pumps out of the gun, not only does it sound loud, I can blow hack saw dust on my work bench about with it.
Is this too high ?
Could I get away with 5 – 6 LPM ?
I am getting a brown deposit on my welds but I think this is normal with a gas mix. It only requires a very little wire brush to remove it.
Is this to be expected ?
I find it easier to run beads right to left. With the torch tipped towards the left. I can then see the weld puddle clearly as I progress. (Top weld bead (Yellow arrows)).
Is this PULL or PUSH ?
Which is better ?
The middle bead is right to left, again the torch tipped towards the left (so over the new bead).
The third (bottom) bead is again right to left, nozzle tipped left (towards the direction of travel, like the first).
The second photo is the inside to show the penetration.
Is this too much or not enough ?
Thanks all
Simon
Is this too high ?
Which is better ?
Thanks all
Simon
