Months after buying my Clarke 151 I am finally finding some time to start mastering the art of Mig Welding!
So far it's not going well even though I am trying get a set up that I had hoped would maximise my chances of getting it right, sadly this is not the case so far.
My set up is as follows;
Clarke 151 Gas/no gas welder
Upgraded Earth clamp
Better Wire!
Disposable Co2/Argon gas bottle
I tried some welds with no gas/standard wire (previously documented on here) and in addition to dodgy welds had loads of splatter.
I then bought the new wire, fitted it (following the guide on here, hope I got the tension right but not sure), and also plugged in the gas bottle!
I then set the welder to recommended settings in the manual for 1.5-2mm steel as I am practicing with similar thickness material.
Below are the results and I can't seem to do any better even though I have tried all sorts of techniques. I also notice that the end of the welding torch is really fouled up, is this normal given that I have only done about 1 metre of welds!
Any help or tips appreciated.
Better Wire!
