what plugs do u use over there .13 amp here . u can run on an extension lead minimum size cable 2,5mm to avoid voltage drop but would depend on what your plug rating is length of cable also the size of your circuit breaker feeding the socketNot meaning to hijack, but if say you are not using a welder at high load, can you run it off an extension cord? I have a BOC (magmate 180p) 180A welder but only currently use it at half and less (max of 60-80A)of that capacity. Any reason I couldn't run it off a cord? 240v system here in NZ. cheers
what plugs do u use over there .13 amp here . u can run on an extension lead minimum size cable 2,5mm to avoid voltage drop but would depend on what your plug rating is length of cable also the size of your circuit breaker feeding the socket![]()
