Highway_Star
Morning all,
I've aquired a Newarc TIG HF control box, you supply it DC and gas, and it provides the HF and gas solenoid.
I've a BOC Transarc MMA box which is AC only, so that's no good as it stand.
Either I build a rectifer to sit inbetween, I'm thinking this would also need smoothing caps and a hefty choke?
Or,
Due to equipment replacement in the cinema game at the moment (every ****** is going digital projection with 3D), I can probably lay my hands to a buckshee ex-cinema arc lamp switch mode supply (inverter to weldy types). This might work well, super smooth DC (typically no measureable AC ripple) and outputs variable between 30-200A. Ouput is controlled by a variable resistor so I'd be able to use a pedal, and switched on/off by a contact pair. Cinema PSUs are 100% duty cycle rated too and the switch mode variety are amazingly compact, can run single phase and amazingly light load on the mains. For example a 2kW xenon lamp running at 75A will pull 30A off the mains using a linear type power supply, you can comfortably run a 2kW xenon via a switcher on a 13A plug.
Now here's where I'm not sure as to the cinema supplies suitability. Typically before the arc lamp is struck, the open circuit voltage will be 100-140v. As soon as the lamp strikes (it's forward impedance drops to somewhere near 0 Ohms, it's a plasma arc contained in an inert gas filled bulb) this drops to somewhere in the 20-30v region. Current will be whatever the unit is asked for via the control pot. Does this sound any use for TIG, or do I need a PSU that maintains high voltage under load?
Or,
