....comes back on after a minute. It happen when the wire gets first contact on the metal. It might be the swan neck metal liner,clogged up with plastic. I might just burn off the plastic,to see if it is the cause. It's a SIP 150
Took the panel off today,and I've spotted the fault http://www.welduk.com/Details.asp?ProductID=643
It's the top right corner component that has the transparent housing that's causing the grief
As shenion mentioned,it was the relay. Got one off ebay for 4 quid,but was unsure,because the relay I took off had 6 pins in total. The one I received had 8 pins
The 6 pins at the end caused me to question whether it is suited. Choosing to bend away 2 pins,and keep 4 pins to match the pcb. Tested it yesterday,resolved
