Getting to grips with my new MIG and wondering if there is a mistake in the user manual. I was checking the power settings table and trying to work out the order of increasing power. However, it seems to be different depending on the material.
There are 3 switches: 1/A, 2/3, Min/Max. Looking at the chart for 0.6mm gas welding it shows following for Aluminium:
0.8 1 2/3 MIN (on setting 1 the middle switch has no effect so 2 or 3 are equal)
1.0-1.5 1 2/3 MAX
1.5-2.0 A 3 MAX, wire speed 8
2.0-3.0 A 3 MIN, wire speed 7/8
For the thickest Al setting it says to use a lower power setting than for the one before ?
For mild steel gas welding:
0.5-0.6 1 2/3 MIN
0.6-0.8 A 2 MIN
0.8-1.0 1 2/3 MAX
1.0-1.2 A 3 MIN
1.2-2.0 A 2 MAX
2.0-6.0 A 3 MAX
On the table for No-gas welding:
0.6-0.8 A 2 MIN
0.8-1.0 A 3 MIN
1.0-1.2 1 2/3 MAX
1.2-2.0 A 2 MAX
2.0-6.0 A 3 MAX
It has the settings in bold in the reverse order to the gas welding table
Does this make any sense - I would have thought the thicker the metal the higher the power and that the sequence of ascendency of the power settings should be the same whatever the wire/material ?
1.0-1.5 1 2/3 MAX
0.5-0.6 1 2/3 MIN
0.6-0.8 A 2 MIN
0.8-1.0 1 2/3 MAX
1.0-1.2 A 3 MIN
1.2-2.0 A 2 MAX
2.0-6.0 A 3 MAX
0.6-0.8 A 2 MIN
0.8-1.0 A 3 MIN
1.0-1.2 1 2/3 MAX
1.2-2.0 A 2 MAX
2.0-6.0 A 3 MAX
