using .8 wire I need to have the welder on power setting 4/1 (13th of 16 possiblesettings) According to the manual I found online that's 33v, it's a 250amp
This is for 3mm alu
Anything less and I get a hairline crack at the join after grinding it smooth....also some destructive testing (grinder...hammer) shows poor results unless it's set high
Does it seem normal to have it set so high for 3mm alu? usually use setting 3/1 ....9th of the 16 settings for 3mm mild steel
This is for 3mm alu
