and the cost of the blades i been getting the mechanical hacksaw blades for 2 quid eachThe main difference of any noteworthiness will be pure and simple speed.
Where you getting your blades from brightspark? Mine takes 14 inch and cheapest I've found on line for 10 tpi I'd about 8 quid.and the cost of the blades i been getting the mechanical hacksaw blades for 2 quid each
pick them up from autojumbles the most ive ever paid was 3 quid eachWhere you getting your blades from brightspark? Mine takes 14 inch and cheapest I've found on line for 10 tpi I'd about 8 quid.
It depends on what you need it for really, most power hacksaws are big, heavy and 3ph. Motors can easily be changed if need be but if your short on space and only using it for light DIY a cheap bandsaw may be the best solution, heavier usage and more space & the hacksaw comes into it's own.
OK, it is similar (a bit more sophisticated though), to my S. Holmes of Bradford. I think mine's around 1920.
Not had it running yet as my shed's not finished.
Even when they're finished, they're rarely usable.
