Davek0974
****!, Drink!, Girls!
- Hertfordshire
Hi all,
I want to build a new powder-coat spray booth, bench-top not massive.
Was looking at using a 15mm x 30mm box frame, build in side panels and fixed into a cube so i can dismantle if i need to get it out of the shop (small door)
Something like 1mm alu sheet skins, riveted on to the box, alu seems cheaper than steel in 1mm thickness but i'm not convinced yet on that, maybe zintec.
My query is - whats a good method of fixing the panels together after ?? Its only 1.5mm tube so tapping threads is out.
Drill right through and use roofing bolts maybe?
I would place the rivets inside so the panels can butt up closely - one reason for using rectangle framework.
Its all on paper at present so open to change
