Eric the chicken
- North Beds, UK
I have titled this thread as 'possible' problem as I'm not too sure whether it's the inverter or the motor. The inverter was bought in April 2011 to run my newly acquired Colchester Student. The lathe, when I bought it was fitted with a three phase motor. The old motor turned its toes up in 2014 and I bought a new one and until recently everything has been fine with the lathe. That was until recently, I turned the lathe on and the motor laboured and turned very slowly.
To show the pattern of use. I don't use the lathe every day by any means. Sometimes I may not use it for a couple of weeks, other times a couple of times a week. So as far as I'm concerned the motor I fitted in 2014 has not had a huge amount of use.
As the inverter was easier to access I spoke to a very helpful chap a the place that I bought the inverter from and he ran through a sequence of checks with me and said that he thought the inverter was OK. I than decided I'd have to bite the bullet and remove the motor from the lathe to check it. I removed the motor and with it on the bench checked the resistance between windings and all were 1.8 ohms. I must emphasise I am not an electrician but according to what I've read the figures I've got would appear to indicate that the motor is OK. In addition the motor spins easily by hand and feels smooth as it turns. The motor is clean and not showing any physical damage.
I'm now fairly certain that the problem must lie with inverter, and this is where I need to ask the forum, does anyone have experience of problems with this particular model of inverter? It's an IMO Jaguar Cub VXR. As I said previously I'm not an electrician and as far as electronics is concerned I don't have clue. Any suggestions welcomed. A suggestion as to a competent repairer would also be welcomed.
I
le
I
le
