ozzman
now then i just went to weld up a car body panel, so i put my 15kg of 0.6mm wire in, turned the wire feed right down and, the motor dont do nothing, it doesn't start feeding the wire till about 4.5 on the wire feed.
which seems a little to powerful for bodywork as i cant even weld an inch without it blowing through. and the arc seems to start wandering and blowing instead of a nice steady sizzle
incidentally my wheels are fine
but my return lead did remove itself from its connector, but if you cant fix that you shouldnt be welding
