Muckmagnet
- East Riding. UK
First thing is that plumbing is a bit alien to me but today I changed the valve things in the kitchen mixer tap. Bit of a doddle really, however when I turned off the hot water isolator valve, that little one that you turn with a screwdriver, it started dripping out of the bit that actually turns and continued to drip once turned on again, but 15 minutes later its stopped and after running some hot water through it to dry it out it remains dry. Should I consider getting it changed or do you think it'll be ok? It's a right pain to get at and means destroying the back of the cupboard to do so due to the amount of pipes running through.
I need either reassuring or worrying
Thanks in advance.
. Thanks in advance.
