re-plumbing the factory soon
2 lots of 28mm pex running around the wall about 8ft up (1 hot, 1 cold)
lots of 15mm pex tee'd off from that coming down to taps fixed to the wall
tee off the bottom pipe is easy, but a Tee off from the top pipe will need to step over the bottom pipe then back in against the wall
anyone have any cleaver ideas?
I used copper last time, so just bent it, decided to change to pex this time, and I've already bought it and all the fittings... I practice bent a bit of pex, and it worked ok... but sprung back to almost straight...
all my google results are people bending it into position and then fixing it down at each end of the bend, don't have that option here (28mm runs need to be pretty close together)
if I bend it and fix it down it'll be the top Tee piece holding that end of the pipe in position... which I guess will leak after a while?
only thing I can think of is have some stainless brackets bent/made to fix the bent pipe too and hold it in position?
