finyuk2005
Hi there
Im needing some help figuring out how to plumb 2 compressors together, but its slightly more complicated than the usual setup,
I have a 4hp 200l single phase compressor and want to connect in a 13hp petrol powered one for doing bigger jobs,
The complicated part is that i have a homebrew cooler setup that i want to run the petrol one through as well.
right now air comes out the electric compressors head (at over 100c usually), it then goes through about 20 meters of hose coiled inside an IBC rainwater collection tank, this cools it to more like 10-15c before it goes through the check valve and into the compressor tank,
If I fit a check valve on the outlet of both compressor heads, into a T piece, through the hose coil, do I then fit another T piece and from there into each compressors tanks check valves? or in the case of the petrol one, its more of a blow off valve type thing.
Any thoughts? Im just not sure if that setup would cause issues with the pressure switch on the electric compressor and the pressure relief for the compressor head, I think the petrol one would be ok, as it just runs the whole time and vents when it gets up to pressure.
I may try and do a drawing to explain it better!
cheers
cheers
