As part of a sill replacement I need to plug weld the thin outer sill to a thick bit of plate near a jacking point. Do I need deep penetration into the thick plate (which is at the back) or can I just use the same settings as I'd use normally use when plug welding to the inner sill? If I'm using maximum power to penetrate the thick plate am I likely to burn up the thin outer sill? Help!
