If you're struggling to ID the power cord, do a continuity test with a multimeter between the copper threads in the head, and each hose end in turn. Only the power cord will give you continuity. Or if you're still struggling, give each hose a squeeze, the power cord has a copper cable inside it and you can feel it if you squeeze the hose, mark it with tape and a pen once you've found it so you don't have to go through it again.. Blow down the other two hoses once you've found the power cord, whichever one hisses at the head when you blow down it will be gas, the other will of course be the cold water feed to the torch head, hope this helps.
