lifechooser
New Member
I have an MX-5 which has been turbocharged. The manifold is described as;
At it's recent MOT, it failed as the manifold had cracked. The garage took the manifold out and rewelded it. I've looked at their work and it looks good, however - on the MX5 forum someone has posted this;
I can't see why it won't work, but to put my mind at rest I thought I would ask some experts.
What do you think? Is it ok, or should I get something else done to it? If so, what? I don't know what sort of welding was done, but as it's a local garage I'm assuming MIG.
Richard
-1.50" Tubing for maximum flow
-Thick Gauge 1010 Heat Treated Mild Steel
-Fully machined flanges (1/2" machined, so somewhat thinner)
-Fully TIG welded
Welding a turbo manifold is a specialist job.
You need to heat it up before welding etc.
A std garage whizzing over it with a Mig will last 2 minutes.
Richard
Suppose it could've been stress relieved after fabrication... maybe i've had too many cynical pills today but i smell marketing BS
). The crack needs to be completely eliminated to stand a chance of long term survivial, with heavy wall pipe that means it'd need veeing out prior to welding. If the repair weld doesn't introduce a bunch of fresh stress risers (read: is reasonably smooth and tidy) then it may last a long time but as said thermal cycling and vibration can result in tiny flaws becoming cracks over time
