Hi Welding Gurus
I'm trying to learn to weld (a self teach that’s not going well) I've borrowed an Arc welder and transformer from my brother who’s currently travelling in Australia so I can’t contact him for any advice. I’ve set the welder up but I’m having no luck actually producing any weld from the rods, they seem to be burning but are only producing miniscule blobs of spattered weld and I seem to have to keep making contact with the work as its not producing an arc, I have tried changing the settings but from the lowest to the highest it’s pretty much the same result. I’ve watched a few of the tutorial videos and I think I’m doing everything correctly but I’m not sure if it’s my technique or the set up. Please can you advise? thanks
Set Up of welder
Welder: Silverline 396689 AC (I’ve tried various mm of rods/welder settings)
Transformer: 1 Phase 40-100~
Input volts 230 – 250
Output volts 110cte
KVA Rating 1.0 continuous
(plugged into a normal 30m extension cable, that’s plugged into the wall)
I've had a look for local courses but they all seem to be full courses for qualifications I could just do with an idiots guide that lasts a day to give me a general idea. is there such a thing?
Set Up of welder
Output volts 110cte
